AB Powerflex 523
AFourie76
Aug 2020
Creighton
I get the F003 fault from time to time. Incoming voltages L1 400V L2 390V L3 410V. Any suggestions on solving this problem would be helpful.
The Knowledge Base has an interesting page on this problem.
It lists several causes/options, but does NOT mention an incoming line filter.
The Knowledge Base (KB) is part of Rockwell's website. Some of it you need an active TechConnect contract to access.
EDIT: The specific KB page you're looking for is # QA22420 "F003 Power Loss on PowerFlex 525/523 Drive"
Search for QA22420 here:
https://rockwellautomation.custhelp.com/app/home
I don't think you need a Tech Connect contract to use the KnowledgeBase, but you do need to sign up with a valid email address. If you AHVE a TechConnect contract, you are automatically signed up for the KB though.
On all A-B drives, the drive does not directly monitor the incoming power, it only monitors the EFFECT that the incoming power has on the DC bus. So all A-B drives are inherently capable of being fed with single phase power and putting out 3 phase, so long as it has enough DC bus capacitance to smooth out the added ripple caused by single phase.
Which brings us to your issue. You EITHER have an intermittent phase loss taking place, OR, you have a bad DC bus capacitor inside of the VFD. If it's a bad cap, you can get a new Power Module for that drive. I don't think the bus caps are easily replaceable and besides, if you lost a DC bus cap, something caused it and that likely caused other damage.
A common cause of issues with the DC bus caps is if you have a contactor ahead o the VFD that opens and closes a lot. The VFD has what's called a "pre-charge resistor" that prevents the DC bus caps from drawing too much current too fast when first energized, which can damage them. The resistor in only in the circuit for a second when you first energize the drive, then it is shunted out. If you are constantly opening and closing a contactor ahead of the drive, that resistor burns out and then the capacitors start failing. If you do have a line side contactor, re-think why it is there.
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
608
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,803
Hello, I wanted to program the parameters for powerflex 523. I gave 480V to the powerflex but I didn't do grounding and turn on the power. But the...
1,521
Hello, I am looking to upgrade some controls and logic on one of our pieces of equipment in our manufacturing plant. I need to be able to force...
4,162
Hello, So I am trying to set the parameters of a pf523 with a Micro850 PLC all done over CCW. I've set it up before with RSLogix5000 where when...
2,440
