The PowerMonitor 1000 is more of an energy and power metering device, rather than an analyzer. It updates the measured voltage, current, and power values (including the min/max log, probably what you'd look at for spikes) every 100 milliseconds, and reports timestamping with 0.01 second units.
It's very easy to get data into RSView from the PM1000 using an RSLinx OPC Server over DF1 serial or using EtherNet/IP. The PM1000 emulates SLC-500 style Integer and Floating-Point data tables.
If you're looking for an A-B device to analyze power fluctuations or capture spikes in voltage or current, then the PowerMonitor 3000 is a better choice.
