AB RS Logix 500 Simple questions...
The other useful function is right clicking an address to give more options.
This will give a full cross reference of all variants of that address (XIC/XIO/OTE etc). Then just click each reference in the results table to navigate to that particular section of code.
Hope this helps.
Rob
Kidblue said:
Hope this helps.
Rob
Be careful with that. If you do a find all for N7:10 and it doesn't find anything that doesn't mean it isn't used. Somebody could have copied to destination N7:5 with a length of 10. Your better off to do a cross reference and then look and see what the previous instructions that were used in the lower addresses.
I don't disagree :nodi: I was just trying to give the OP a few 'quick tips' to finding basic addresses used in his particular situation with the Analogue input scaling...
Again, hope it helps (not hinders!!)
Rob
I'd found the "Find All" thanks all the same. Although I didn't know about someone potentially writing to a previous address with a length that would overwrite the address that was being searched for. Thanks for the tips..
Rob
I know what you are saying, I just wanted to make sure that uptown47 knew about the 'find all' limitations, I found out the hard way and it was ugly. :cry:
59
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
88
96
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
179
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
85
