AB - Scalling 1794-IE8
aattanayake
Apr 2009
Greenville
What I have:
1756-L61 (Controller)
1756-DNB (DeviceNet scanner)
1794-ADN (Remote Node)
1794-IE8 (8 analog input card)
My inputs are all 4-20mA and need to select the module to accept this input range. When I open the node from RSNetworx I can't get the control byte mapped to the PLC. I does not show any control output words. All I have is the 8 16 bit words for the 8 channels.
Can someone help me get the control word mapped to the PLC please?
Hi Guys I'm using Vijeo Designer as HMI, and we're monitoring the water levels in a water well of 6 meters deep. I created the water well in...
1,321
Hello friends; I am new with Mitsubishi system. I need some example to handle the 4-20mA by using FX-2n-4AD which is attached with FX-1N-14M...
3,558
Dear All; Good day. I have a flow meter range 5-70 Cm/hr and out is 4 to 20 mA. first i want to ask how i calculate that at 13 mA what is flow...
1,700
Hi All I am doing a Tank Gauging project. In there all the tank parameter like level , temperature , pressure are coming into a master...
3,879
i'm a newer in PLC programming... anyone please help me about how to do analog scalling in PLC, please sent me an example the ladder for this...
3,287
