Scalling Advise
jcp
Feb 2010
Multan
369
Dear All;
Good day. I have a flow meter range 5-70 Cm/hr and out is 4 to 20 mA.
first i want to ask how i calculate that at 13 mA what is flow reading?
Second for GE PLC 90-30 cani use the 0 to 32000 counts for that range?
Regards
Hello,
Linear scaling is:
output = ((input value - input low) / (input high - input low)) * (output high - output low) + output low
You can use any range the system provides.
Hi Guys I'm using Vijeo Designer as HMI, and we're monitoring the water levels in a water well of 6 meters deep. I created the water well in...
1,321
Hello friends; I am new with Mitsubishi system. I need some example to handle the 4-20mA by using FX-2n-4AD which is attached with FX-1N-14M...
3,557
Hi All I am doing a Tank Gauging project. In there all the tank parameter like level , temperature , pressure are coming into a master...
3,879
i'm a newer in PLC programming... anyone please help me about how to do analog scalling in PLC, please sent me an example the ladder for this...
3,287
Hi friends; I purchased a new analog module ALG 223. I connect the transmitter 0 to 87 PSIG. Set the configration as follows low=0000 high=32000...
1,551
