AB SCL5/03 connected to a FPX-C30R
Aug 2007
Barranquilla
Hello, how are you all doing?
First of all, i want to thank for any info you can provide.
I have an autometed process controled by the AB SCL5/03 and connected to it there is a PanelView via the rs232(DF1) port. Now i have to conect this PLC to a FPX-C30R wich is controlling other thing raleted to the same process, my question is how can i get these to plc's talk between them. the FPX-C30R has to send data to the SCL5/03 in order to be viewed in the panel view.
Again Thank to you all for any help you can give me...
bye
What protocols does the Panasonic controller support ?
If you can send ASCII strings comprised of your data to the Channel 0 serial port of the SLC-5/03, you might have a chance to communicate between these two controllers directly.
Yes, you will have to move the PanelView to the other port. Your original designer may have done you a disservice by attaching the PanelView to Channel 0, which is the most flexible and powerful port on the SLC-5/03 controller.
The Panasonic PLC has a maxium of 3 serial port, it could be a rs232 or rs485 layer and between the protocols it handles modbus profibus ethernet...
I was thinking in conecting these two plc via a converter that changes protocol dh485 (SCL5/03) to modbus (FPX -C30R). It is possible to do that. I mean even if they are from differen companies...
I am getting confused trying to figure out how to properly do a 'message path'. I am trying to replace a SLC5/03 with a 1769-L32E PLC. I need to...
1,832
I did this a long time ago. Either I forgot how to do it or I don't have the correct driver. I'm connecting via my COM1 Serial Port using a...
2,117
:scratch: hello I posted a problem yesterday about not being able to communicate with allen bradley slc5/03 cpu thru a rs232 cable. had some...
2,773
Hello everyone, I'm having issues with connected components. I got a new laptop and I installed all the RA programs I need without problem. I was...
342
