Message Path question from L32E to SCL5/03
jjensen
Mar 2016
Pittsburg
I am getting confused trying to figure out how to properly do a 'message path'. I am trying to replace a SLC5/03 with a 1769-L32E PLC. I need to talk to another SLC5/03 PLC over modem/telehpone lines to receive Utility meter values.
I have attache a word doc to help details where I am now.
Welcome to the Forum !
Try using the path "2, 10", as the SLC-5/03 slave device is using Source ID = 10 in its configuration.
Strictly speaking, Full Duplex devices are supposed to ignore the destination address, but when they do send a message, they use the Source ID as their own node number.
The SLC-5/03 master was also configured for "Full Duplex Modem", suggesting it is using hardware handshaking.
Check the CompactLogix system configuration's Serial Port tab, and be sure that's set for Full Duplex instead of No Handshaking.
I am trying to read and write data from Control Logix L23E and a Micro 850. My path in the message is 2, 192.168.2.183 192.168.2.183 is the ip...
713
Hello I have two Compact Logic PLC’s that I’m needing to message data from. I’m having trouble with the communications path portion of the setup...
2,018
I am looking at an old program and doing a retrofit on a sorter. Looking at the ethernet interface, see attached pic, I see a path that is =...
1,480
Thanks for any help! I can usually figure these out, but after an hour of misses I don't have any more tricks up my sleeve. I've read some great...
1,327
So I'm using a single message instruction to read data out of multiple VFD's through an HMI screen. This is not new to me and I've been doing it...
3,914
