AB SLC connected to Modem
tutu
Apr 2008
Toronto
30
Hi guys
does any body knows that if I configued SLC ch0 to connected modem, do I still can direct connecte my laptop via RS232 cable?
my SLC cpu is SLC 5/03 Ch0-RS232(9Pin- D shape) ch1 RS485(RJ45)
Yes, just make sure you have the proper cable as handshaking may be required. See below for correct cable
The configuration of channel 0 for modem or direct connection will be the same. Use a null modem cable like the 1747-cp3 for a direct connection to your computer. But to connect a modem to channel 0 you will need a straight through cable.
There is a choice for protocol control, see picture below.
With or without handshaking.
I'm a mega noobie when it comes to PLCs and the such. I'm a network guy. We are currently experiencing an issue where the SLC immediately faults...
1,908
This is my first posting: I have Problems with Uploading a Panel View 550 connected to an SLC 5/03 Allen Bradley SLC 5/03 1747-L532 PLC...
13,979
Hi, I have a little problem of understanding the AB-network, so I hope you can help/ fix my problem: I take three Micrologix1000 and connect...
4,808
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
108
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
108
