Hi, I am after a little help if possible?
I am unfamiliar with AB processors/software, but was asked to look into a 'CPU Fault' that was flashing.
After connecting to the PLC, I checked the diagnostics and from the RSLogix 500 software, the only thing that appeared abnormal was the fact that the following status was indicated:
Fault/Powerdown Rung#S:20 (12)
After searching the menus I tried clearing the fault etc, but nothing seemed to changed.
Reading the online help did not present anything, and I could find no reference to a '12' block anywhere in the program.
I tried the various programming modes and also tried changing some of the variable in the diagnostic screen, but to no avail.
If possible, could some indicate what this error means, and if it is possible to remedy/locate the problem (assuming it is located in the PLC it self)
Regards,
henno2000
Regards,
henno2000
