AB SLC500 and RSlogix
secs
Aug 2015
Office
65
Hi all.
I do a lot of fault finding but not a huge amount of programming with the plc's. My question relates to the AB SLC500. I need to simply add a Ex If Open type contact to an existing running PLC. Can I do this LIVE or do I have to do it offline and upload the complete program again?
The unit is on a running machine and I dont want to take it offline as I do the upload so I either have to do it live (if possible) or when the machine isnt being used.
Many thanks
It depends on the software and the SLC you have.
The SLC5/01 and 02, I don't believe support online editing.
RSLogix500 starter does not support online editing.
depends on what version
Hi all.
Many thanks
It depends on what version software you have Starter does not do it. It may effect the programs scan time so watch when you do it operations may lag.
Thanks all. I will do it offline and download. I thought as much...
Peter
We did not say it could not be done. If you have a processor other then a SLC5/01 or 02. And software other then the starter it can be done.
The SLC5/03,04,05 do support online editing.
RSLogix500 Standard and RSLogix500 Pro do support online editing.
...and the RSLogix 500 software edition???...o_O
Go to...
Help>About RSLogix 500...
Hello, I am new to the industry and was wondering if someone could tell me if there is a way to check the module properties of the SLC500 series...
866
Alright, here is what I know. In the lab we are building a new OSIsoft PI system and need to inject some real life data into the machines for...
11,779
I have a simple problem, but a simple solution eludes me. I need to generate a string with the last 5 digits being serialized each time the...
10,977
292
can the slc500 5/05 send a email and text over Ethernet ?
195
