Ab To Mitsi
delph
Jul 2002
suffolk england
Hi
I am converting a A\B program for use on Mitsi can anyone help with the following questions
=1 I take it that B in A\B is the same as M in Mitsi.
=2 I have two S bits in A\B they are S:115 IN/IZATION BIT
and S:45 TIME BASE.
can anyone tell me the equivalant in Mitsi.
thanks delph
"I take it that B in A\B is the same as M in Mitsi"
No, "B" means Bradley and "M" means Mitsubishi... (only kidding!) :D
But really, you are correct that B and M are equivalent...
You can use M8002 to do the same thing as S:1/15 (first scan)
S:4/5 is simply a clock pulse. Someone else will chime in with details about the duty cycle of this particular bit (I always get confused with it). The Mitsubishi has 4 clock pulses...
M8011 - 10ms
M8012 - 100ms
M8013 - 1 sec
M8014 - 1 min
The AB program is probably just using this to flash a lamp, so M8013 can be used.
beerchug
-Eric
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,086
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,219
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,418
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,833
Hi, I have just wired up (might be incorrect) a Q Series PLC with an Input Card GX40-S1 and an Output Card GY40P. my issue is now in software I...
1,586
