Mitsi Q Series in/Out Card Help
Big_Robo
Nov 2016
England
81
I have just wired up (might be incorrect) a Q Series PLC with an Input Card GX40-S1 and an Output Card GY40P.
my issue is now in software I fire the output, it shows on the small LED at the top the number of the output but no physical output comes on.
I have 24v into terminal 17 and 0v in terminal 18. Am i doing anything wrong.
I have 24v into terminal 18 and 0v in terminal 17. Am i doing anything wrong.
Hi Rob.
The drawing shows +24V on Pin 17, are you sure this is correct?
Regards
Daniel.
Sorry yes that is correct, I have 24v on Terminal 17 and 0v on terminal 18 sorry will correct post now. Yeah outputs still no good.
I have tried a new card, all outputs near enough. I must have done the wiring wrong I will do a little more investigating.
Thank you for the quick replies
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,815
hi all regarding : mitsi q series ethernet qj71e71-100. there's an old coax network at a client's chicken factory that's fallen over. it...
1,929
Hi Guys, I have just been asked to help someone establish a scada connection to my PLC over tcp and it's just not happening and I know nothing...
1,339
Hi folks i was just wondering if there is a multiple device rst command instead of having to rst every single one, say i wanted to mov a value of...
2,989
Hello again.:D I am attempting to set up ethernet coms to an A series Mitsi processor. Processor is A1SJH/ Ethernet card is A1SJ71E71N3-T...
4,211
