This might be a shot in the dark since our setup is pretty archaic, but here goes:
First, here's a description of our setup: The workstation is running Windows 98 and contains a 1784-KT DH+ interface card. The interface card is connected to our PLC-5/20 device to channel 1A (3-pin DH+ port). Our version of AB6200-PLC5 S/W is 4.12 (pretty old huh?).
We're having issues connecting to our PLC device in the AB6200-PLC5 S/W. When I attempt to go online (invoke the F1 command), I receieve a variety of errors including "Error loading communications driver" or a message that the PLC5 device is not present.
We use the AB6200 S/W in our calibration procedures and this is the first time we ran this in a long time. I checked the online configuration settings (F2 menu) and I believe we are selecting the correct DH+ KT device. I'm not sure about the address settings though. In our calibration procedure, we turn the keyswitch to REMOTE mode prior to starting up the AB6200 S/W. Per the procedure, we shutdown all instances of RSView prior to starting the AB6200 S/W so there are no driver conflicts.
Note, when the keyswitch is in RUN mode, we are able to run just fine in production mode using our RSView and RSWorks products. The communication issue only appears in this older AB6200 S/W. Unfortunately, we need to use AB6200 since it's part of the procedure.
Interestingly, when we invoke the WHO ACTIVE command in the AB6200 S/W, the PLC device is identified as a PLC-4 instead of a PLC-5. Is this the source of our problems? Is our version of AB6200 even compatible with Win 98? Should we be booting directly to DOS before running ABMENU.exe? In RSView, the PLC device is correctly identified as a PLC-5/20.
I'm relatively new to the PLC world, so any troubleshooting advice would be greatly appreciated. Thanks!
