OkiePC
Can I do a registration positioning application with a 1HP ABB ACS355 drive using encoder feedback and a registration eye in order to quickly center a carton on a scale and stop at it's center point? The center point need only be calculated once from the HMI for each Recipe, and/or actual measured (HMI calibrated) center point, and I may want to just make the slave conveyor match the supply conveyor surface speed during transfer, quickly accelerate once transfer is complete, stop for weight qualification + HI module settling time, then when the operator is required to adjust the "patty count" in these cartons, the G3 will display it as "+2" or "-1". If the operator adds/removes patties they must use either the footpedal or a big gloved hand touch button to release the box. If it enters the scale, stops briefly and is already within the target weight, it automatically is released without operator intervention.
Not sure how accurate I really need to be, but looking for a registration typ of move (the belt has a leading end thru beam to initiate "gearing" to the infeed belt, and I will want to be able to perhaps do the same control for the infeeding belt and the short downstream belt with pseudo electronic gearing.
Can I do this with the ACS-355 under a low end Compactlogix which supports 1769 i/o?
If I could do it with a digital interface, I would consider switching to a ML1500 and the 1769-WS, and translate my RSLogix5000 program into Micrologix code for the next three scales I will be upgrading.
