ABB ACS355 and OPCA-01 Connection Cable
matts_persic
Dec 2015
Reno, NV
Does anyone have experience connecting to an ABB ACS-355 drive using the OPCA-01 cable and DWL2.7 or DrivesWindow software. Two different ABB guys said the OPCA-01 is the cable to use, but I can not get it to communicate. I am connecting it to the keypad port and have tried using a RS-232 and a RS-485 port on the PC running DrivesWindow Lite 2.7 and DrivesWindow. Neither works. I have successfully connected to ACS800 and DCS-x00 using fiber and serial, but can't get a connection to the ACS-355. Any help would be greatly appreciated. Surprisingly the ABB folks in New Berlin are no help, and they generally are great with tech support for our company. Matts Persic [email protected] 775-842-8640 mobile.
The manual says that you need an OPCA-02 adapter for the ACS355.
Verified: the two cables have the same pin configuration and should be inter-changeable.
Looks like the difference is the -02 is a CAT5e shielded cable.
Thanks for the reply. I have both cables (-01 and -02) and neither works. Your cable pinout clearly shows it is an RS-232. I've tried a bunch of different COM port settings and I generally get "No Drive Detected". Using the ACS800 settings I get a "CRC Communications Error". Have you connected to a ACS355? If so, what are your PC COM port settings?
You only need to tell DWL what com port you are using. It will handle any of the other settings. Make sure something else isn't using the port, including any Rockwell software, or the ABB OPC server that is used by DriveWindows
That's interesting. I wasn't able to connect until it was in remote, while in local I got "No Drive Connected" message.
Currently waiting for Schneider Customer Support...:D ... meanwhile: Brand new ABB ACS355 with FPBA-01 Profibus DP adapter connected to a six...
7,732
hi! couple off months i instal this drive in a machine with a motor 15hp. the user goes up and down the spead with the cursors now he says that he...
1,375
Some VFDs support permanent magnet motors. For instance ABB ACS355. Has anyone tried using anything like this? What VFD / motor did you use...
7,545
Hi, I have a question outside the plc area, but I thought someone would have an idea. I was comissioning an ABB ACS355 drive (frequency...
17,399
Can I do a registration positioning application with a 1HP ABB ACS355 drive using encoder feedback and a registration eye in order to quickly...
3,264
