ABB ACS800 over Profibus
luccass
Jun 2009
UK
56
Hi guys,
Started coding some blocks in Step 7 for Profibus comms to ABB ACS800 drive. Looks like typical Profibus DPV0 device, but...
I need to read Actual frequency, current, power and torque and display them on HMI - as usual scaling is needed between raw values from the drive and the final value.
Could you please advise what sort of parameters / factors need applying to scale raw values as the AB manual drives me bonkers?
We use FPBA-01 Profibus interface, so looks like we have to use ABB Drives communication profile. Correct me if I'm wrong as never used ABB drives and not familiar with terminology.
Thanks!
I have a sample FB using PPO4
If your interested, PM me with your e mail address
I had a look at your code this morning. It shows how to read from and write to a drive, but no scaling (except of actual current in %)...
In the ABB drive 16384 is the max value right??
Just add an "in" to the function block as a scale factor.
Then just do the math on the pzd and send it "out" the function block
Easy
do any one know how to do programming with ABB AC800M plc programming,and specifically how to do programming for analog signals and PID Block?
Please help me out,
Rushik, you must start a new posting to ask a different question like that. You are "highjacking" a thread when you do this and it is unacceptable in this forum.
You will get good help here but you must start a new posting
I am having some problems here to figure out how to talk Profibus DP with ABB ACS800 frequency converter. I use a mitusubishi Q system and right...
5,201
Hi, does any one has sample S7 project about ABB ACS800 control on PROFIBUS? I have serched the 'whole' web to find something about it, but so...
8,529
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
212
Members of this forum helped me out a great deal a couple of years ago with a question I had regarding acceleration during torque control of...
4,410
I am getting an AD1_PLACE1 fault on my drive and am stumped, any pointers would be appreciated!
1,885
