ABB ACS800 torque reference help
g.mccormick
Jul 2012
IN
961
I am using a ACS800 regen drive to drive a 500hp motor for a engine dynomometer application.
I am currently running the drive via ethercat comms in speed control and to control the torque absorbed by the dyno, I am manipulating the torq limit parameter (20.04) via SDO write over ethercat. This works fairly well, but I think I would like to try to switch the drive into torque control mode. I will then use analog signal to the drive for torque setpt. I have both +/-10V as well as 4-20MA analog outputs available.
My issue/non-understanding is this:
The drive settings for torque control seem to be to me atleast all motoring torque reference/control. This would mean power into the motor instead of regen torque which is what I am wanting. It is not intuitively obvious to me that if I assign a bi directional AI1 (+/-10V) as the Ref2 (which should be torque reference), will a negative voltage tell the drive to control regen torque?
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
210
Members of this forum helped me out a great deal a couple of years ago with a question I had regarding acceleration during torque control of...
4,404
I am getting an AD1_PLACE1 fault on my drive and am stumped, any pointers would be appreciated!
1,884
Hi All, We have a ABB ACS 800 Drive, Have 2 AO for RPM and current output. As default setting, both are available on X9-12 terminal. I am...
2,242
Dear team, i need to run ABB ACS800 two drives in master follower mode.Im using ABB RDC0-03C option kits with fiber optics lines. As they...
2,365
