abb ai531 4-20ma signal problem
rushikesh794
Aug 2016
andhra pradesh
hi i am using signal isolator to take an analog input to my plc.but after connecting with in small time 2sec or 5min's the signal is perfect after that in signal isolator it showing disconnected(signal break indication) but in plc it showing the short circuit value(+32767).if i use digital multimeter in series to see ma it showing perfectly in both plc side and signal isolator. only digital multimeter is connected it showing perfectly at signal isolator side.if i connect with out signal isolator it showing perfectly.when we connect the ma signal through signal isolator to plc only we facing problem but after occuring problem i disconnect the signal still it showing the fault value and indication in plc.
please help me. In advance thanks:rolleyes:
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
149
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
211
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
448
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
185
