ABB Automation builder
rQx
Oct 2010
Trelleborg
1,051
I got a small project I'm going to make with ABB PLC.
I have used codesys before and I'm not a fan.
I try to use a TOF but with the ability to reset it when the time is counting, I can't find a Timer reset function and I can't have write access to the timer internal variables either. How is this supposed to be done?
/Tim
I know diddly about ABB and even less about Codesys, but in other timers I have seen disabling the timer executes a reset i.e. in ladder, if the rung feeding a TON goes false, or the rung feeding a TOF goes true, then the timer resets.
E.g. this is a poor-man's repeating timer using that feature, if the poor man doesn't care about accuracy. The XIO(FLASHER_TOF_DONE=T4:0.DN) resets the TOF on the next pass after each pass when the TOF Accumulator reaches 99, and then that same XIO restarts the TOF on the pass after that:
I Agree, unless their software is different, most timers will reset when the enable goes to false unless it is retentive.
Hi, I am new here, also I am a beginner in PLC programming and connection. I have a project in which the programming are made for 5 plcs, the...
322
Hello Experts, I recently stumbled with an issue about ABB VFD ACS800 connected with B&R PLC X20CP1484-1. This ABB VFD ACS800 somehow got...
332
how is ABB in Automation field,i iwsh some one help me in this and is it has it's own plc's and scada systems?i visit them site but i need more...
2,389
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
112
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
162
