B&R Automation Studio X20CP1484-1 with ABB VFD
DenZ_P
Jun 2016
SomeWhere
64
Hello Experts,
I recently stumbled with an issue about ABB VFD ACS800 connected with B&R PLC X20CP1484-1. This ABB VFD ACS800 somehow got defective and needs to be replaced with ACS880. The problem is that customer does not have existing backup program of the B&R PLC. I tried to go online and upload the HW config and attached images is what i got. There is no field bus connections with the VFD. How i can get or see the field bus connections and configure this new ACS880 VFD into the B&R controller?
Just new with B&R PLCs now. thank you in advance!
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
566
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel -> add object ->...
428
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel, it seems to me...
640
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,214
Hi all, I am working on a ladder program in AS and I was to trigger a reading on my IO link sensor every .5 s, and use that value to run a...
541
