abb opc server for ac800m 5.0.1 configure
sunil_work
Jun 2010
mumbai
Dear All,
I am having compact control builder installed on 1 pc(pc-1) & connecting to abb plc (ac800m ) through opc server panel( ethernet connection).the download of the program code is working correctly.
I have another pc (pc-2)with wonderware- intouch installed. it is communicating with the abb plc through abb opc server panel( ethernet connection) correctly.
However, whenever i download a modified program to the plc through pc-1, the scada connection(in pc-2) to the plc gets disconnected.
When i try to reconnect from the opc server panel, it says that it needs some files, which even after browsing say that the revision number is incorrect."
I then need to manually copy files from "opc server for ac800m" folder from pc-1 & paste it to corresponding folder in pc-2 to restart the connection.
actually i tried configuring the working folder for opc , but there seems to be some mistake in that.
Kindly suggest as to what could be the mistake.
Thanks in advance.
Sunil Nair
Post abb opc server for ac800m 5.0.1 configure
Dear All,
Thanks in advance.
Sunil Nair
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
185
Hello everyone, We use a Siemens Softnet IE Lean(OPC Server) to communicate with a Siemens PLC. Now we have to change the PLC. Now we use a...
2,454
Hi everybody. I don't know if this is the right section to post...however.. I'm working with abb ac500 and i'm trying to connect with OPC the...
8,058
Hi guys, i need to make available the value of the control builder program into a TCP/IP network using OPC server. Could anybody plz tell me the...
4,435
Hello everyone. My problem is: Two pc's in network, same user and same pasword, first, CON2, with the opt ABB.DciServer V2.0 reading from DCU...
4,434
