ABB plc or DCS?
Mar 2005
In our plant we are using ABB Master Pieces MP200/1 and two Advant500 series Operator station at CCR-3 (central control room)
while in CCR-1 there is AB system ContolLogix5000 and RSView system
combination.
Can anybody tell me that are we using DCS, SCADA or PLC system ?
I dont know the exect difference between DCS and PLC.
pls. Help me.
Thanks.
PLC vs DCS
I maybe way off here, but I think the significant differences between a PLC (Programable Logic Controller) and DCS (Distributive Contol System) are:
1. How the proccessors scan the I/O.
PLC-in scan top to bottom
DCS-scan all I/O ussually based on change.
2. The refresh speed of the data or scan time.
PLC-Depends on the length of the program, loops, Sub routines, etc...
DCS-Typically more real time data.
3. Cost
PLC-More cost efective on a per I/O basis than DCS.
If I am going to apply a new control system to, for example, a chemical proccess that would tend to be easily upset, I would choose the DCS.
If on the other hand I am adding a package conveying system, a PLC would be more that sufficient. Of course this is an over simplification of the problem, but I think you see my point...
Opinions are like bosses, everybody has one.... :eek:)
Daniel Camacho
The ControLogix platform does not scan the way a traditional PLC scans (i.e. top to bottom left to right). The ControLogix allows you to schedule I/O updates based on change-of state, and also provides the opportunity for event-based scheduling of block of logic or subroutines.
MP200 sounds old. DCS or not. Probably the AllenB equipment is better in any way you compare no matter what it's called.
I would like to introduce a dedicated forum for ABB control system,this is a really good platform to learn ABB control systems,just like...
1,310
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
473
Hi, I am new here, also I am a beginner in PLC programming and connection. I have a project in which the programming are made for 5 plcs, the...
327
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
461
Hi Guys, Here I have started to work on some difficult task, I hope I will get solution here. we have ABB CI-840 Master IO Module needs to be...
607
