turbohamad
Respected Members;
I am going to design the PLC control system.
The requirement as under:
1. Input/ Out put modules are SIL 2 certified.
24 DI, 18 DO and 8 AI.
2. Controller are IP 20, Minimum memory size 2048 KB, Memory type user data 1024 KB, supply voltage 24 v DC.
3. Control system design is simplex (No Redundant required) but modules should be SIL 2 Certified.
So I select following
1. CPU PM 583-ETH
2. DI 524 or DX 581-S (Combo 8 DI & 8 DO), Which one is better DI 524 or DX 581-S
3. DO 562 or Use DX 581-S,
4. AI 581-S for analog Input.
5. SM-560-S
My first ambiguity is with CPU PM 583 which models of DI, DO and AI modules are configurable?
Is SM-560-S is necessary for the simplex system?
Further more I choose the HMI CP 676 15" Screen which communicate with RJ 45 (Ethernet) with Controller.
Please guide me best possible solution to select the products?
Regards
1. CPU PM 583-ETH
5. SM-560-S
Regards
