abb veritron dc drive
geoker
Apr 2010
lebanon
HEY SIR HOW ARE YOU HOPE YOU ARE FINE?
please i need the datasheet
or terminal diagram for the following drive.thank you very much ABB GNT2018001R0003 Veritron 75A DC Drive ABB
BEST REGARDS,
abb veritron drive
yes i'm sure. well the drive has been manufactured in 1988 so before you started selling abb. and it was also when brown and boverie before the fusion to become abb so i appreciate if you have some contacts to see some old manuals and scaning them.i contacted abb but i had no reply until now.so its depressing.thank you again for your reply hope you can try to see something for me :) best regards
The only practical conclusion is to discard the old drive and replace it with something more modern. 22 years on a drive is about two normal lifespans. I doubt that any components are available anymore, much less the documentation.
Sorry, but I think that is the unfortunate truth.
thank you guys i appreciate your help.well i guess without a manual i'm have no solution that to put one new.but its very hard to change the logic of the machine
thank you for the datasheet but it isn't the one.well i only have the indenet number gnt 2 018001r0003.But i think the type is :abb veritron drive aad 1401
hope this will help.thank you
Help for ABB Veritron PAD/PSD Drive
Sir,
May I request you to help me to get the ABB Veritron PAD/PSD Drive manual
( 3ADT218083R0614 ) and if posible to provide GSD file for Profibus Interface Module for this drive ( BX5402 - 3ADT220026R0001 )
I will be very much thankful to you for your support
velumanoj ----------
Hi, I have old inverter ABB named VERITRON. At the moment I am looking for the spare part for ANALOG INPUT , type PI1301 P/N : GNTO163100R0001...
2,523
I have problem with old ABB DC Drive "Veritron GCB-6". Can somebody help me with documentation for this drive?
3,344
Hi we are using an ABB Veritron SCR system to power our drawworks DC motors and we are getting fault code F10 coming can anyone give some advice...
1,888
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
89
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
141
