JoelAB
I am new to this forum and coming here as a novice to PLC work and signal However, my questions here hopefully won’t pertain to PLC programming. I have been tasked with connecting telemetry equipment on to various water meters in a water system to provide data for regulatory reporting. For the most part the water meters are already wired to the SCADA system but data retrieval from that system is not possible due to security issues. I’ve resorted to using the pulse output to the telemetry equipment to pull the meter data. (For most of the meters the pulse output is un-utilized in the SCADA system) However, I’ve now come to two water meters which have the pulse output (and 4-20mA) being utilized by the SCADA PLC. These water meters are ABB WaterMaster Mag Meter and Transmitter. I’ve attached an image of the pulse signal wiring from the user’s manual. D01 is for forward flow and is being used, D02 is for reverse and is not utilized.
Q1: I’d like figure out a way to connect to the pulse signal in parallel at the water meter transmitter location. Is this even possible since the pulse signal is powered through the PLC?
Q2: It seems that it might only be possible if I could wire my device in parallel with the PLC load, and with an equal resistance. Is this correct?
Q3: Are there any other options I am not thinking of, that wouldn’t require connecting to the PLC or SCADA system? Security issues prevent me from doing this.
Q4: Lastly if anyone is familiar with ABB WaterMasters, is it possible to use DO2 for forward flow by reprogramming the transmitter?
Thank you
Thank you
