Abnormal behavior Compact logix controller
rejoe.koshy
Dec 2011
kolkata
195
I have a 1769-L32E,series A, compact logix controller which suddenly stopped working (as in all the outputs dropped out). The status of the PLC indicators are as under:
RUN- off
FORCE -off
BAT - off
I/O - off
OK - steady green.
It seems that the controller has lost its project or has being flushed by it. When an attempt is made to download the project, the following errors show up and the download process is aborted:
"Error : Internal Object Identifier (IOI) segment error
Error : Failed to download tags."
Finally I got to download the project but the issue presented itself after 6 hours of running time.
I cant find any information which is in line with above status indications. I am assuming that a major non recoverable fault might have forced the controller to flush out the program but in that case the "OK" indicator should blink red ..
Confused ..pls help!
RUN- off
FORCE -off
BAT - off
I/O - off
OK - steady green.
you may have issues when trying to download instructions in that firmware version that it doesn't support.
you may want to try bringing the firmware version up to as high as you can take it for the program and the processor.
It has been running with the same firmware version for 6 years now. I dunno whether firmware issues would crop up suddenly
I'd go with checking the power supply as RAY stated. The SLC family was notorious for dumping its program when the power supply spiked or sagged voltage to the CPU. I have not personally had that issue with the CompactLogix family though.
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
107
I have Beckhoff panel pc connect with the terminal. The panel PC is running twincat 3, after update to twincat3 v3.1.4024.12, it come out an...
2,018
Hello, Guys and galls I have a problem in my Mitsubishi FX3U PLC, it was showing a flashing red light, the problem occurred by itself as far as I...
3,366
Hello All...good day...really need help here...We got acopos 1090 behaving like really faulty. During power-up the ready and run led were...
1,592
hello all, I encountered below problem. the rung is as shown below. m8000 -||--+-------------------[D102 D100 K4]...
4,015
