About Exter T100 touch operator panel
Shohadawy
Aug 2008
Egypt
66
I'm using an "Exter T100" touch operator panel and the configuration software "Information Designer". I'm developing an application in which the operator should enter a maximum and a minimum value as a range. I want my application to give him a warning when he trys to assign a minimum value that is larger than the maximum value or vice versa. How can I implement this by the Information Designer?
Hi Shohadawy.
There is a function that you can use.
In analog numeric and under the tab called dynamics you have a function called Maximum Value / Minimum Value.
So in your analog "min" choose "Maximum Value", mark mode = analog and enter you "max" adress there. Now you cant enter a value greater then max in your min adress.
Just do the same for your max (but with "Minimum value").
Regards
//edmund
I'm using an EXTER T100 Touch panel and I have two questions: 1- I'm using the demo version of the Information Designer tool ... When I run the...
4,153
Hi All How can manage multiple station through single Exter T100 panel? i have 20 filling station connected to a single compact logix plc...
4,134
Hi, I am trying to connect a Siemens S7 300 to a HMI Exter T100 through MPI. From what i´ve been told i do not need an adaptor for the RS232...
14,107
Hi, I'm currently having an issue with a Beijer T70 HMI. We have 2 HMIs talking to a Yaskawa motion controller via modbus over ethernet. The...
582
Spent the best part of the day trying to figure a problem with the Beijer Exter series no protocol mode. I got it sussed and so thought I would...
3,315
