about s7 200 communacation port burn
njdujian
May 2003
jiangsu
HI,ALL
I have a system with s7200 PLC and GP hmi.when I connect the PLC and HMI,few minites, the PLC's communacation port burn. I think the cabel is good,the PLC and HMI is new. Please tell me how?
thanks very much!
For something to get hot (burn) you need energy, there must be some electricity going where it should not go and so creating heat. The S7-200 port has 24V on pin 7 and 5V on pin 6, make sure you have no connections to those pins. Otherwise disconnect all cables going to the plug and then add them back one at a time until you find when the heat starts.
Bryan
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
53
30
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
102
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
84
