about SIEMENS mmc card
njdujian
May 2003
jiangsu
hi,all
1,can u some way to modify the mmc card's capability. eg, modify the 64k to 128k...
2,used the file s7imgwr.exe v1.0 I have a message"error 23 write to MMC card",what's mean? but used the version 0.95 usually OK
Yeah, and modify a $5 bill to a $50, and $10 to a $100 ... Carry on. It's your risk.
I seem to remember seeing somewhere that the Siemens MMCs have actually 4x the quoted capacity (a nominal 64KB actually has 256KB of memory on it). However there was also a suggestion that Siemens have a writing/reading algorithm to spread data across these 4 areas. Otherwise, if you continually wrote to the same data cells on the chip every time, the life would be significantly shortened.
Ken
I am not want the $100....
I see a paper say: the MMC of 64k-4m all the MMC 16m,I want to prove it.
hi, i want to purchase new MMC card for Siemens PLC (CPU 315-2 PN/DP) please provide vendor contact details for india from where i will able to...
2,749
Hello. I have a problem with MMC 8 MB. After failure while downloading to CPU my memory card was corrupted. STOP blinks on CPU. I tried to format...
2,333
Can anyone confirm that I need an ordinary MMC card for backup and restore of the program in a TP177B? The manual just says use a >16MB card...
7,898
At this point I have a question concerning the size of a memory card for a siemens 300 CPU (the small memory cards). - How can you determain...
7,063
Hi Does Siemens supply images for mmc's that have been accidently corrupted or formated?
80
