About Starting Diameter Calculation using Position of Web & Spindle
a151218
Nov 2012
taipei
[FONT=新細明體][FONT=&#26032]I test about winder machine.I use linear velocity and winder shaft rpm [/FONT][FONT=&#26032]calculate[/FONT]</SPAN>[FONT=&#26032] diameter.But I found when the linear about 5m/min,the [/FONT][FONT=&#26032]calculate[/FONT]</SPAN>[FONT=&#26032] [/FONT][FONT=&#26032]diameter is [/FONT][FONT=&#26032]not accurate and high linear velocity the diameter is very close.[/FONT]</SPAN>[/FONT]
[FONT=新細明體][FONT=&#26032]I found [/FONT][FONT=&#26032]the formula from siemens web [/FONT][/FONT]
[FONT=新細明體][FONT=&#26032]that the title is [/FONT][FONT=&#26032]Starting Diameter Calculation using Position of Web & Spindle[/FONT][FONT=&#26032][/FONT][/FONT]
[FONT=&#26032][FONT=新細明體]The formula is[/FONT][/FONT]
[FONT=&#26032][FONT=新細明體]Spindle Starting Diameter = angle factor * (dancer outer diameter + dancer inner diameter) * (dancer
ending position – spindle starting position) / (spindle end position – spindle starting position))[/FONT]
[/FONT]
[FONT=&#26032][FONT=新細明體] [/FONT][/FONT]
[FONT=新細明體][FONT=&#26032]anyone can tell me how to [/FONT][FONT=&#26032]calculate[/FONT]</SPAN>[FONT=&#26032] [/FONT][FONT=&#26032]diameter use the formula or give me a [/FONT][FONT=&#26032]example[/FONT][/FONT]
[FONT=新細明體][FONT=&#26032]and [/FONT][FONT=&#26032]explanation[/FONT] my question for me:confused:</SPAN>[FONT=&#26032][/FONT][/FONT]
[FONT=&#26032][FONT=新細明體]1.How can I find the angle factor?[/FONT][/FONT]
[FONT=&#26032][FONT=新細明體]2.My dancer roller is fix diameter and what is dancer inner and outer diameter?[/FONT][/FONT]
[FONT=&#26032][FONT=新細明體]3.What is spindle position?[/FONT][/FONT]
Hi, I am attempting to turn on an output for one second, every thirty seconds, but am having some trouble. I have a XIC with S:1/15 (first pass)...
595
Rather new to structured text. I'm trying to edit a machine so that it will reinitialize with some push buttons held in for 10 seconds. Pushing...
2,752
Hi Guys, I'm using an ABL33ER with Panelview 600. I have datalogging running on the HMI using the view studio datalog model on startup of the...
1,144
Hello guys, I have windows 10 on virtualbox guests and not on the host. On a windows 10 guest I have TIA Selection tool V2022.06. When I...
1,515
Hi This message popped up when I created a new hard disk (image) (TwinCat IO Server. TwinCat is not starting because of an invalid device...
1,552
