TwinCat is not starting
aladol
Mar 2017
sudan
Hi
This message popped up when I created a new hard disk (image)
(TwinCat IO Server.
TwinCat is not starting because of an invalid device request. Please upgrade your TWINCAT level).
What is the problem??
* Card type : Beckhoff FC3102
* The same Software works on the old Hard disk
Did you verify that the Ethernet card is recognised in the master settings?
Did you run in elevated (administrator) mode the batch file C:\TwinCAT\3.1\System\win8settick.bat?
If your OS is Windows 2000 I would imagine you need to use TwinCAT 2. My advice was regarding TC3. I am, so sorry, not familiar with TC2.
I am trying to get the TwinCAT Master running on a Windows 10 PC, but cannot make it run, except in the Config mode. When I try to change it to...
7,496
Hello: I am using TwinCAT 3 for my project. Whenever I open my project all of my functions, function blocks and HMI's gets open. How can I...
1,638
Ok working on TwinCat for first real time. I cannot seem to find a way to do a compare in the ladder. The way our driver works (from our...
28
13,848
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
86
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
