TwinCAT 3.1 Error starting
pchakravarty
Nov 2019
California
I am trying to get the TwinCAT Master running on a Windows 10 PC, but cannot make it run, except in the Config mode. When I try to change it to "Start/Restart", I get the following error.
Error starting TwinCAT system!
Init4\RTime: Start Interrupt: Ticker started <> AdsError: 4132 (0x1024, RTIME: Incompatible software detected) For further information start the event viewer and open the application log.
I looked at the event log and see the same error message.
I am new to TwinCAT and PLC programming in general, so am not sure how to fix this. Could you please help?
Thank you for your reply. I did check the thread and tried out what they said, but with no success. I am currently trying to reinstall it as an admin and see if that was the problem.
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
155
Gents, I'm trying get some SEW Movigear motors in control by a Beckhoff PLC which is TwinCAT 3. The SEW motor is connected by EtherCAT and is...
1,311
Gents, I'm pretty new to Twincat 3 and facing at an annoying issue when try to go online with a remote Beckhoff PLC. At out plant we have 10...
4,675
Hello: I have a TwinCAT embedded PLC and for years I was able to access it through the AMS NetID. Recently updated Windows 10 and I was not able...
16,231
Hi! i try to use string as variable name in a forloop my problem is tahat my if insturktion not allow strings as variable name. my declaration...
2,375
