Absolute encoder grey code with micrologix 1400
itsdkumar
Jul 2016
hyderabad
Hello everybody.. I am new as programmer. I got a project in which i have to control some mechanical cams. I have micrologix 1400 1766-L32BXB and a rotary encoder (absolute grey code, 9 bit). I do not have idea about wiring of absolute encoder is done and also how to use its signal in plc. Is Micrologix 1400 is compatible with absolute encoder ??
Plz help me out. The RPM of shaft is 160.
Hi. I've got an absolute grey code encoder (10 bit) on a bi-directional mobile shuttle. I've converted the grey code to a 0-1023 integer value...
5,036
Hi. Can anyone explain how an Absolute Encoder works with the SSI interface and what Grey code is all about?
9,983
Hello. An absolute encoder on a rotary axis gives values in range -2147483648 to 2147483648. When value is > 2147483648 , the encoder value is...
20
2,307
I have 2 Absolute Encoders 8192 steps per Rev. (Model TR Electronic CEV65m-11003) These Encoders communicate to the PLC5-60 via Parallel push/pull...
1,519
Hi guys I am new to Encoders, so I have limited understanding of how to actually configure it, to the situation that I am in. Using this Absolute...
1,587
