abt hyperterminal
dhruvit
Jul 2012
gujarat
If I Have a computer running Hyperterminal, and it's connected to the controller using serial commport-1. How can I use hyperterminal to test and trouble-shoot the serial communication. Can some one point me to a manual or a tutorial on how to use Hyperterminal to test serial communications (RS232 or RS485)? Say I don't know what the PLC/Controller is sending and I would like to capture the data stream, how do I do that?
What make and model of PLC are you using ? Most logic controllers use a vendor-specific serial protocol.
Hyperterminal is a very crude tool for serial protocol analysis; you will almost certainly need something more sophisticated. I use RealTerm extensively.
Are you attempting to "write a driver", or troubleshoot a link between existing systems, or something else ?
Edit: I found your other post, where he's trying to make an Arduino emulate an SLC-500, or vice-versa.
thank you sir
actually i m using micrologix-1100
and whatever data i m going to get on comm port i will send it to Arduino
i just want to see what data i will get when i suppose on or off the switch in my programm
or what should i get on hyperterminal a string or what?
can i able to see something in my hyperterminal if yes then how? it is then possible for me to communicate with Arduino
THANKS FOR YOUR REPLY
can anybody tell me how to read data from PLC using hyperterminal and which type of data i will get i m a beginner for plc so please help me
2,329
hello all i m a student from INDIA i want to do data exchenge between two serial ports using PLC SOFTWARE(SIMULATOR) by using com port...
2,019
Hi, im using the built in high speed counter of omron cj1m cpu22. I will be connecting a rotary encoder to the high speed counter. The rotary...
2,490
sir,im going to do project in plc based bottle filling module that fills 5 bottles automatically.can u plz give the tips to construct ladder...
1,743
Good Afternoon, I Am Parag From Mumbai, Like This Plc Site , Is There Any Site For Dcs Is Available. Thanks In Advance. Best Regards...
1,693
