abt hyperterminal
dhruvit
Jul 2012
gujarat
can anybody tell me
how to read data from PLC using hyperterminal
and which type of data i will get
i m a beginner for plc so please help me
Welcome to the forum,
If I got you correctly, you are trying to read PLC internal memory area. I doubt what you trying to achieve is possible with Hyper terminal.
Hyper Terminal reads ASCII from a port, unless your PLC is sending data out thru it.
Regards
i want to know when i m online using my micrologix-1100 and supose if i toggle the i/p bit and my o/p is on so what kind of msg or string i will get on my hyperterminal actually i want to send that data to other embeeded controller so plz help me
The data you want to send out of the port is determined by you by putting the necessary logic in the PLC based on your requirements when you trigger the input.
Without putting any logic in the PLC the port gives out nothing, - not even a :ROFLMAO: or :cry:
Read the ASCII instructions on your software help topics or the instruction set reference from Rockwell
TAHNKS for your reply plz tell me which instruction i should use in my PLC
i m using micrologix-1200
and how?
so the it can show me on my hyperterminal
If I Have a computer running Hyperterminal, and it's connected to the controller using serial commport-1. How can I use hyperterminal to test and...
1,647
hello all i m a student from INDIA i want to do data exchenge between two serial ports using PLC SOFTWARE(SIMULATOR) by using com port...
2,021
Hi, im using the built in high speed counter of omron cj1m cpu22. I will be connecting a rotary encoder to the high speed counter. The rotary...
2,491
sir,im going to do project in plc based bottle filling module that fills 5 bottles automatically.can u plz give the tips to construct ladder...
1,743
Good Afternoon, I Am Parag From Mumbai, Like This Plc Site , Is There Any Site For Dcs Is Available. Thanks In Advance. Best Regards...
1,693
