AC power sensing module
Sorry about that, but I just checked out of curiosity, and it appears they pull about the same power, so the micro electro-mechanical relay may be a valid choice.
No reason to be sorry... we are all just trying to help each other, I was surprised that AD only offered 24VAC on the output side :unsure:
I have a requirement to sense the true power used by a submersible pump so that I can monitor pump performance. Anyone using anything that can do...
2,949
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
300
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
77
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
51
