AC Torque Motor Control with PLC
Tenbaum
Jun 2006
minnesota
HI guys new to this site, I just starting working with plcs and have a question. I have two AC Torque motors (advantage is these ac motors provide a constant torque at stall without burning out the motor). I need to control the torque automatically with a plc (the work with tension sensors to provide the proper amount of torque to keep constant tension in the spooling fiber). In order to control the motors you need to vary only the voltage supply; i.e. variable frequency drives will not work. Someone mentioned an analogue triac output but I have not seen any sort of variable voltage ddrive that can connect to a plc. Does anyone have any solutions. I have to use these AC torque motors, I think servo motors are way beyond my budget. Thanks.
Alex
I'm not sure why you can't attain torque control with a freq. drive. I have used drives to control output voltage instead of frequency (we actually used it to control voltage to a large electric element heat exchanger) . I can't find any info on the type I have used, but it appears the A-B 1336 PLUS II has selectable freq/voltage control.
http://www.ab.com/drives/1336PlusII/index.html
Because he is using an actual torque motor, not a standard induction motor. A vector drive, either with an encoder on the motor or sensorless mode works as a torque source with a regular motor. A torque motor is a different beast.
Hey thanks for all the help, but any more information you guys have would be great. You all are obviously a knowledgeable bunch. Yeah it is actually a special ac motor (here is the link from oriental motor http://catalog.orientalmotor.com/vi...motors?&plpver=11&forward=1&backtoname=&pane=) it is able to supply constant torque in stall. But I really need to just control the voltage, one reason being the variable frequency drives maybe excessive for what we're are trying to achieve and they may not work for our purpose. I'm am working on the Nova neutrino detector and we need to keep things within range of our monetary limit. Thanks again.
Alex
Tenbaum: Why not ask Oriental what they recommend?
And then dope slap the person that bought them in the first place without knowing how to control them & consulting you.:(
I doubt very much that this type of motor is what you want. Please describe in much detail what you are doing.
Okay
There are two fiber spools each with a mounted ac torque motor. The spooling fiber is being spooling onto a spooling fiber for a particular length. The fiber is then de-spooled from both spools and cut in as its being pulled from both spools. The machine is only in motion about a third of the time but a certain amount of tension needs to be applied even in this stall mode in order to prevent tangles (its a wavelength shifting fiber and is very expensive). Hence the reason for ac torque motors to supply torque to create this tension. That same level of tension needs to be regulated while the machine is in motion (via tension sensor inputs to the plc) Essential the program logic will ideally take tension level inputs and send a vary ac output voltage to the motors (PID) for continuous tension control. thanks again.
tenbaum
hello everyone ! i have kinco's motors ( if anyone has already worked with one of these it will be very helpfull ) and i try to apply torque...
3,922
Hi All I have a problem with my cartesian robot Z axis. When the Power to the motor is turned on/off there is a slight drop. The motor has a...
3,174
I am building a test rig which will have two 50HP dc motors connected together, which will me used to test the motors/drives under current...
3,372
Hello everybody, I am fairly new to PLCs, although I have one year left in my three-year Industrial Automation course so I have had some...
21
12,710
We have aspindle that we drive with Siemens Sinamics S210 servodrive and servomotor1FK2104-4AF10-0MA0 and gearbox...
1,645
