Torque(current control) motor test rig
star_watcher
Jun 2007
Manchester
21
I am building a test rig which will have two 50HP dc motors connected together, which will me used to test the motors/drives under current control.
My question is how to physically connect the two motors together. Should I just have a fixed coupling or should I have some sort of clutch arrangement?
Any suggestions?
Any suggestions?
I think you need to describe the setup better - for example
1. What is the load, variable (or?) and how do you adjust it
2. What are you testing - motors or controllers or?
3. Why do you want to couple and uncouple motors?
4. A brief explanation of test parameter and desired measurements wold help.
Dan Bentler
Hi guys, Its not a production rig its just to test drives and motors off line from the main system.
My concern is if for some reason we have a stall condition or overload condition.
Dan,
1. The load is variable, on the test rig it will be via a pot. On the main system it is via a computer voltave output.
2. I am testing motors, tachos, and controllers.
3. I dont need to uncouple the motors I'm asking do I need a clutch or is a fixed coupling ok?
4. The rig is to test the operation of mainly the motor controllers but also the motors.
Thanks for your help.
I would pick a coupling that can withstand some miss-alignment that wont be too difficult to change when you need to test a motor. Maybe a rubber "tyre" type coupling.
Nick
Hi All, I have a large servo indexer chassis that uses an AB servo and Kinetix 5500 drive. It seems logical to me to try to limit the amount of...
2,118
It is said that vector sum of flux and torque current equal to total current drawn by the motor but there are also some currents flowing due to...
1,873
Hello! We are having some trouble with pieces falling in between a chainbelt and destroying alot in the process. The machine is using a Altivar...
3,293
I was looking at the Display Group parameters on a couple of our Powerflex 40s that were having OL faults today. And I noticed there were two...
4,156
Hello to all, I have one dilemma and hope someone here will be able to help me. In our plant we're using Electro-hydraulic actuator that moves...
2,144
