Acceleration after gearbox
aand74
Dec 2005
Deinze
131
From an existing configuration I know the default set acceleration of the motor in rev/sec².
Attached to the motor is a gearbox with ratio 1/10 (gearbox output is 10 times slower then motor).
To know the default acceleration after the gearbox, do I have to devide the motor acceleration by 10 or by 100 (square)?
divide by 10:
TL;DR
Unit Analysis (multiply by 1)
Code:
1 GearboxOutRev(olutions) = 10 MotorRev(olutions)
 1  GearboxOutRev
--  -------------   = 1 (unity)
10    MotorRev
Acceleration:
    MotorRev
 A  --------
       s
 = A x 1
because multiplying by unity does not change the quantity.
And since [1/10 GearboxOutRev/MotorRev] is also unity, we can substitute tha, in blue below, t for unity:
Code:
      MotorRev    [COLOR=Blue][B]  1 GearboxOutRev[/B][/COLOR]
=  A  --------  x  [B][COLOR=blue]-- -------------[/COLOR][/B]
          2        [B][COLOR=blue]10   MotorRev[/COLOR][/B]
         s
    1        MotorRev  GearboxOutRev
=  --  x  A  --------  -------------
   10            2        MotorRev
                s
    1        GearboxOutRev
=  --  x  A  -------------
   10             2
                 s
Calculus
Code:
 GearboxOutRev   =   --  x  MotorRev
dGearboxOutRev    d(1/10 MotorRev)      1     dMotorRev
--------------  = ----------------  =  --  x  ---------  [Note 1]
    dt                  dt             10        dt
 2                                                    2
d GearboxOutRev      d(1/10 dMotorRev/dt)      1     d MotorRev
---------------   =  --------------------  =  --  x  ----------  [Note 1]
      2                     dt                10           2
    dt                                                   dt
Note 1:
There should be a
Code:
+ MotorRev d(1/10)
on the end of that, per the product rule:
images
but since 1/10 is a constant, d(1/19) = 0, so that term has been dropped.
I like L D[AR2,P#0.0]'s answer.
BUT
drbitboy, that is good info if the gear ratio changes.
We have a command called the Advance Gear Move where the gear ratio changes using a cubic spline. This way feed forwards can be generated for the slave axis. Without feed forwards the slave always lags.
Basically we map the master's position, velocity, and acceleration to the slave's position, velocity and acceleration using the cubic spline and the chain rule.
Yep, I have a Mathcad worksheet for that too.
BUT
But we are PLC programmers.
L D should have writed 10dec, so everyone will understand it 10 instead of binary which is 2 on dec. 🔨
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,828
Members of this forum helped me out a great deal a couple of years ago with a question I had regarding acceleration during torque control of...
4,416
Heres my question guys I have the quick start guide, but when I look at the display for my acceleration time parameter, I have four zeros to the...
1,246
Good Afternoon , We have a number of Kinetix 6000 Servo Drives and motors. I'm trying to understand these a little ( really alot ) better...
6,375
Good Morning , I'm working on a project that I may need to change the acceleration rate according to which recipe is being ran. I took notice...
2,237
