mohmes
I have a Redlion G308 HMI with 2 Ethernet ports. This has 4 Yaskawa MP2600 servo drives and 12 Honeywell UDC3200 temperature controllers connected to it via Ethernet Port 1 (192.168.4.145). Ethernet Port 2 is connected to the building network (10.10.4.160). I would like to be able to access the webserver on the Yaskawa drives via the building network by routing through the Redlion G308, but I cannot seem to get this to work.
I have the gateway on the Yaskawa drives (192.168.4.146 to 192.168.4.149) set to 192.168.4.145 and I have IP Routing turned on for the Redlion G308. I have toyed with setting the gateway of Port 1 to 0.0.0.0 or to 10.10.4.160 with no apparent difference in results. I have also used the windows route add 192.168.4.146 mask 255.255.255.255 10.10.4.160.
Does anyone know where I might be going wrong or if this can even be done?
If I can get access to the Yaskawa webserver working then I would also like to try to send configuration settings to the Honeywell UDC3200 controllers, but this uses Modbus, so I don't know if it will work.
