PierrePaulPaquet
I'm working on a project with an Allen-Bradley PLC, so we are using Studio5000. I have a bunch of things that communicate through ethernet/Ip and I verify the communication with every one of them. If I lose the comm, I latch something like an alarm depending on the situation.
Now here is my problem, we have some blowers that were made by an external company and are controlled by a Beijer X2 controller. I don't have any access to the controller, and the only information I can read/write are sent directly to some tags I created in Studio5000 (they are just basic tags, not even produced/consumed, I have no idea how it works). Now those tags are only updated when there is a change in the value in the Beijer X2 controller. This mean that I don't have a good way to verify if my communication is live. I can't do something like overwrite the value and if it doesn't change back, then I lost my comm because if the value doesn't change in the Beijer X2, then my overwritten value will stay even if my comm is good.
I usually use things like the connectionfaulted bit when I have a module with an eds, or GSV's when I use a generic ethernet module, but since the Beijer X2 controller doesn't work through a module, I don't see how I could use that.
I was thinking that maybe there is a way to use a MSG instruction, but I'm not very familiar with them.
All I have to work with is an IP Address.
Could I use something like a Generic Ethernet Module with None in the communication format and then use a GSV to get the EntryStatus? I've never tried this before so I don't know how it would work and I can't test it right now.
Any other suggestions?
Thanks.
Thanks.
