Our customer has an issue with an ACS800 drive and 150Hp Motor on a hammermill that I need to resolve. The system has been installed for several years, and on the weekend the motor failed. One of our guys helped to replace the motor, and noticed that when starting the drive, the motor will ramp foward for roughly 2 sec then reverse for the same time, then jump forward to where it should be in the ramp. Ramp time for the system is around 4 minutes.
This problem has only started after the new motor was installed, and no parameters were changed (that I am aware of) on the drive.
I remember seeing this happen on a ACS350 with a 1hp motor several years ago, but I wasn't the one to correct it a can't remember what was done.
FYI this isn't exactly a graceful way to start a 150hp Hammermill...
