Hi all.
First thanks in advance.
I'm working with a conveyor application. It has a ACS800 that ran a motor to drive a reducer and finally a chain conveyor.
In general its running fine... we use fieldbus RETA01.
We want to ran at 3000 rpm. drive receive the info from plc and starts... but the speed just reach 2780 rpm.... no more..... I check the Speed limits on 20.02 parameters.... which is set to 3200 rpms....
Now, seems like limits are a calculation from motor data plate on 99.xx parameters.... and change does not effect the speed....
DTC mode is selected.... supervision parameters are now for testing purposes....
Is the any way to make the motor at higher speed that what VFD calculate?
Thanks for your help
