Activations problems
Modotarin
Feb 2013
Mexicali B.C.
Hi, I have a problem with the activation of RS Logix 500 in the FactoryTalk Manager I can not see the software license and I have it in the folder that it mark in FactoryTalk Manager.
In the advanced options of FactoryTalk Manager server status is stopped, I pressed refresh and nothing happens.
could you please help me, I can do
I'm using the latest version, I have it installed on a laptop with windows 7 pro 64 bit, in test time use the RS Logix 500 and achieves communicate with PLC's and implement programs without problems
After adding a license to a server, I have noticed it can take several minutes to appear in some of the client lists and refresh doesn't speed it up.
Even added to the local path it's slow to appear and refresh...sometimes I have not been able to make a new addition appear without rebooting. There is probably a service you can restart, but this is usually a rare problem that will go away once that license has been located once.
The only other advice I can give is to double check the path, and also your rights on that Windows PC must be Administrator.
With Win7, you may need to turn off User Account Control, so that your Administrator account actually gives you administrator level privileges.
For my first time, I put a copy of Studio 5000 and Factory Talk Activation Manager on my customer's machine (On-logic Windows PC), then use remote...
2,520
Hi, I am using studio 5000 and trying to share my activations between my host pc and guest VMs. I have managed to get this to work using a...
270
Hi All I did a search, and I didn't find anything related. Rockwell has changed their activations system again, and you now need the legacy...
1,181
Our company has 10 licenses. We have about 10 engineers covering 2 shifts. Lately, when I've been trying to open RSLogix 5000/Studio 5000, I've...
1,694
My original post: A customer has a minor recoverable fault on his Control Logix 5550, and needs V6.01 to go online...
3,997
