AD Productivity Suite compare values
diat150
Mar 2006
Louisiana
1,474
Looking at the compare values instruction, it seems as though you have to use 2 separate boolean tags to perform a greater than or equal to function? Am I missing something? If I try to write to the same tag, the tag I am writing seems to always follow the equal to state even if the value is greater.
so if I want to turn an output on if a value is equal or greater I need to create a separate tag for greater than, and equal to and then parallel them to a coil?
Am I missing something or a better way? Obviously most PLC have >= instruction.
Are you entering the compare contact from the keyboard? If so, double click it and you should see the options to choose any of the standard compare functions.
If you drag the compare instruction from the toolbox, it automatically opens this window:
thnaks had a brain **** and was using cmpv. still getting use to productivity. I know it is 1000 times better than the old directsoft software.
Yeah, I am not a big fan of PSuite...too much fluff, some major pet peeves, but WAY better than Directsoft.
I had not seen the CMPV instruction. I had to reopen a file and look at that after your reply. I guess it is slightly more compact than 3 compare rungs with Coil outputs?
The PSuite designers got carried away with extra instructions, and extra tag properties that can lead to unpredictable outcomes (like Initial Values) but the thing that turned me off the most was starting bit numbers at "1". I have never seen any computer software do that until I dealt with it in PSuite.
I am really liking the Click Plus, but its fixed memory rather than tag based and has I/O limits. The DoMore is cool, but have had some hardware problems with it.
For example, I need to set 1011-0011-1100-0011 into a memory location. I am trying to look for MOV function in Productivity Suite. However, I...
1,289
3,790
I think this is great news! After many years waiting for it, I'm happy we have User Defined Structures for the Productivity PLCs. For those not...
18
6,788
Hello everyone, I am just starting to use productivity 2000/3000 and got some questions: 1) How could I get the modbus address of a tag if I dont...
2,350
i have an instance where a limit switch activates a solenoid. My issue is that my on timer only works so long as the limit switch is held down, or...
3,068
