AD Teminator I/O compatability
smiller
Aug 2003
Arizona/Brazil
116
As a distraction from the AB vs. Union thread... Can anyone tell me if the AD Terminator T1H-EBC100 Ethernet comm module is compatible with Allen Bradley TCP/IP? specifically Logix 5000? I talked to AD support and he said that it was not and I would have to use a third party (Prosoft) Modbus/TCP master module, but the way I interpret the catalog it is. I am interested in trying Teminator out and have Modicon Modbus/TCP and AB Ethernet networks. It would be a big plus to have a product that can be configured for use on either network.
Thanks.
Steve
From what I can tell by looking through the manual it doesn't look like it supports Ethernet I/P. You might be able to format your own UDP messages out of the CLX Ethernet port but I kind of doubt it.
Keith
The Terminator T1H-EBC100 communications module does support MODBUS TCP/IP, so if your Ethernet controller supports standard MODBUS TCP/IP then it will work.
It will not work with Allen Bradleys Ethernet I/P (CIP or non-CIP versions).
I have been handed a control panel to commission with an S7-1500 in it, and I am the greenest of novices at Siemens products. I have also been...
2,430
Hello everyone, Have a quick question. Can i safely replace a controlLogix 1756-L62 with a controlLogix 1756-L55 battery and vise versa. I have a...
3,109
I am trying to connect with a Compact Logix L32E with version 20 firmware. I have downloaded ver. 20.05 software, it says it is installed...
1,935
Can any one shar a compatability matrix for WW 2012 shoing newer OS what is the highest version of MS Server that this support or are we better...
951
Hello Everyone. I know with Rockwell stuff, the series card is important, cant' just swap a series A input card with a serB, even if the catalog...
1,915
