ADAM-4024 and ADAM-4520 Module power supply
arran
Sep 2015
UK
53
Just a quick question, does anyone know if the ADAM-4024 and ADAM-4520 modules are able to take 24VDC power supply without the need of it being unregulated.
When the module was ordered there was no mention of it needing unregulated, but a friend of mine said it requires unregulated is this true?
Thank you for the help in advance
I always use regulated power supplies for the Adam 4000 family.
What could be the reason to use only unregulated power supplies??
All I need is to power the ADAM-4024 and ADAM-4520 model, if you say you use regulated power than I assume it fine to use it for this as well.
The datasheet for the 4000-series is http://e-oktat.pmmf.hu/webgui/www/uploads/1016/ADAM-4000.pdf
I was having a look at this it mentioned about 24VDC unregulated and than it said it can accept any power between +10 to +30 VDC does this mean that the supply voltage doesn't have to be regulated?
You can type unregulated in the find box to go to the section where it mentions what I have explained above.
I normally feed my Adam modules from a switchmode power supply or off batteries and a battery charger and have never had an issue.
who can teach me how to edit tag adam 4017+ in citect scada? real external I/O
882
After great help on the forum getting a Red Lion G3 HMI to control & communicate with Advantech's ADAM-4055 D/IO modules, the next step was to...
4,370
Thanks to some great advice on this forum after I asked the question: Could I communicate with a remote D/IO module (Read & Write) using only a...
3,956
Does anyone know how to get a ADAM 6217 Analog Input module talking to a Productivity 2000 PLC over Ethernet/Modbus?
1,886
