Add an expansion card to micrologix 1100 or 1200
EffSee
Oct 2017
USA
19
i am trying to add an expansion card to a micrologix 1100. i am only testing as the real addition will be on a 1200. currently im unable to add the card to 1100. i pick the card from list,downlaod,and when i try to go online i get a major error. What am i missing?
What card are you trying to add? How many Cards?
The 1100 only allows 4 add on modules but the 1200 can take up to 6.
Can you give us more info? Maybe a screen shot of your set up in RSL 500?
Are you actually adding the physical card to the ML1100 when you do the download? If not, it will see that it is now configured to look for that additional card, will not be able to find it, and so will fault. Bullzi's suggestion above will override that - if you set the PLC to ignore the configuration error, then the PLC won't fault out if it can't find certain modules. Obviously, this is not good practice and should not be done on a production machine, but for the purposes of testing your setup, it should be fine.
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
126
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
123
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,079
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
590
