Add chart data to RsLogix5000?
rankhornjp
Dec 2008
Georgia
241
I'm trying to display the concentration of a solution on an HMI. I want to do the calculation in the PLC (ControlLogix). The problem is that it is not a linear calculation. I have a chart that shows the data. It has Specific Gravity across the top and Temp down the side and gives you the concentration in % in the middle of the chart. Is there a way I can input the chart data into an array(?) and create a scale?
You could program it into a literal three dimensional array, use file search/compare to get the first two dimensions and then indirect addressing with the results to get the third and then display it on the HMI.
DEAR FRIENDS, CAN SIEMENS PLC'S ( OR MAY BE ANY BRAND PLC ) MAKE DIFFERENCE (COSIDERING THE SCAN TIME ) WHILE SCANING A SAME CODE IN LADDER OR...
2,312
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
120
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,072
