Add Comm Module to PV600
asmaint2
Supporting Member
Jul 2009
Defiance, Ohio
31
Good Evening Everyone,
I have a PanelView standard 600 touch only 2711-T6C2L1X(DH485) and I have a 600 T6C20L1(Ethernet). Is it possible to take the Ethernet comm module out of the 20L1 and mount it in the 2L1X? I know there is a place for it, but how do you get the 2L1X to recognize the new comm module?
Thank you in advance for any advice.
You cannot substitute communication modules in PanelView Standard terminals.
It would be neat if you could, but you can't.
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
120
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,052
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
588
